Yamaha DSP-A2 with Sub/Sat system
Discussion in 'AV Receivers & Amplifiers' started by topgun_GA, Sep 7, 2005.
Tags:
  1. topgun_GA
    topgun_GA
    Jun 26, 2003
    231
    +4
    With the speakers set to "small" on my yahamha dspa2, the crossover is 90hz which is below the 120hz that my sat speakers can manage. The only way of getting around this appears to be connecting the main speaker outputs from the A2 to the high-level terminals on my eltax sub. Aside from this solution being less than elegant, I will also be losing out on all 90hz-120hz sounds from the centre and rear channels.
    Is there something I'm missing here? would the loss even be noticable?
    The alternative would be to ditch the A2 and get another (~£100) receiver which is better suited to sub/sat systems.
  2. AMc
    AMc
    Nov 20, 2000
    6,885
    Near Norwich
    +3,483
    I think you're jiggered there mate. I asked some similar questions about my old A5 and the general consensus was that the fixed cross over is a pain.
    Can't seem to find the threads here which is a pain as there was quite a lot of good info IIRC
    I don't think you'd be missing out on much from the centre and surrounds at that frequency but your mileage may vary...
