Yamaha DSP-A2 versus Denon 3805
Discussion in 'AV Receivers & Amplifiers' started by Northmoorblue, May 19, 2004.
Tags:
  1. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    I am thinking of purchasing the Denon 3805 as part of upgrading my system. At present I have A Yamaha DSP-A2. Will the Denon be that much of an improvement to the Yamaha. Does anyone have any experience of performance comparisons.
    THX
    Northmoorblue
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I would suggest that the deonon will have vastly superior procesing and of course it will have alot more features.... if it were me, I would consider it a good upgrade.
    ad
  3. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    Thanks for your opinion. I've seen them advertised for as low as approx £760, so I guess it's a good buy for this price.
    Northmoorblue
  4. Bassbin
    Bassbin
    Mar 16, 2003
    2,395
    48
    Leicester
    +56
    I've just upgraded from an A2 to a used Denon 3802 and it sounded a lot better in my system so I'm sure the difference will be even greater if you go for a 3805. I've found the Denon works better with my Paradigm speakers which always sounded a bit muddy with the Yamaha (probably the combination of very smooth speakers and amp). The processing is greatly improved in quality and ProLogicII is excellent if you watch a lot of TV.
