Yamaha DSP 800 Cutting Out
Discussion in 'AV Receivers & Amplifiers' started by ajryan, May 5, 2002.
Tags:
  1. ajryan
    ajryan
    I have recently had problems with my DSP 800 cutting out i.e. powering off. Turning it back on displays the message "Check speaker wiring" before resuming normal service. Turning the volume down solves the problem but the volumes at which it is happening are not particularly loud.
    Anybody else experienced this or know what the problem is?
  2. Geoffc10
    Geoffc10
    Check the speaker cable connected to the amp to make sure no strands are touching other terminals. Also check the power rating of your speakers. They might be too powerful for your amp. What is the OHMS rating for your speakers?.
