Yamaha dsp 3090
Discussion in 'AV Receivers & Amplifiers' started by Ryan288, May 14, 2003.
Tags:
  1. Ryan288
    Ryan288
    Please help, need some advice,
    I have a Yammie 3090 and wish to ask about its AC-3 decoding. Does the amp only produces digital surround if a digital signal from a co-axial cable is connected. I have a DVD player which has the digiatl co ax output, but the amp does not regonise it. Using a optical cable the amp indicates a PCM source but it will not go into AC-3 decoding.
    Is the big yammie a bit outdated now?, as it does not support DTS and Dolby digital from DVDs. I have had the amp from new and I am pleased from its perfomance. Can you suggest some solutions so that I can get digital surround from the amp.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,372
    107
    Leicestershire, UK
    +461
    Unfortunately I think your amp is approaching obsolescence.
    If it can't decode DD or DTS, then the best you are ever going to get out it is Pro Logic which while surround sound isn't a patch on modern DD / DTS.
    Your best bet would be to look at replacing the amp with something more modern, using your existing speakers (assuming they are okay). Something along the lines of the Marantz SR4300 or Yamaha AX630 would be a good place to start looking.
    Vikki
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    AC-3 decoding is for Laser discs via RF normally you could add a Yamaha DSP E800 i think thats the model number, which should addd DD/DTS to your current amp but buying a new av reciever which can be bought for less than £200
  4. nathan_silly
    nathan_silly
  5. Family Guy
    Family Guy
    It is Dolby Digital yes - but IIRR, only had one digital coaxial socket, which was primed for LD RF and not PCM or DD.
    I know that the A2 defo had this, and the digital inputs are not assignable either.
    No 6 channel in either, so virtually rules out upgrade to dts.
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    The A3090 can be modded for a multichannel input, but it's really not worth the cost.
  7. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    309
    +25
    We had this machine in our demo room, and i owned one,
    you CAN use DVD and get DD5.1 but as said not DTS.
    I used it with LD and DVD no problems.
    At the time i used optical for DVD.
    A really good amplifier but a little dated now as far as features and decoding formats go.
    Check your setup for digital inputs/outputs are correct.
    Good luck.
  8. nathan_silly
    nathan_silly
    Thought so. Smug mode! :)
    Have you set the DVD player's digital output to bitstream?
  9. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
    I have a 3090 and it can do Dolby Digital via coax from a DVD using the coax CD input. Second down on left as you look at it from the back. The top one is for an RF AC-3 out from a laserdisk.
    If you press the CD, or any source button, on the remote repeatedly you cycle through the input modes - Auto / Digital PCM / Digital AC-3 and Analogue (depending on what connections you have in).
    Nathan is probably on the right track - look at the DVD setup menu first and make sure it is set correctly.
    Also some DVD players multiple coax/optical outs - my Pioneer 606 has 2 coax as well as 1 optical, but one of the coax is PCM only so would not give a 5.1 signal out.
    www.videotec.co.uk do various upgrades to this and other amps but I decided it was not cost effective. They do a 6.1 input which will give you DTS if your DVD has an onboard DTS decoder.
    HTH
    Gus
  10. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    when i had my 3090 i had Dolby Digital through the digital coax and the picture through the svid marked dvd to select id press dvd to get the picture and then press CD the picture would hold and the knob would turn to cd giving me the sound in DD
    stick with it coz its a great amp:smashin:
  11. Family Guy
    Family Guy
    But my point is still valid - there is no dedicated coaxial socket for DVD on the 3090 - optical sounds better to me anyway....:devil: :lesson: :D
  12. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    9,754
    2
    +7,127
    Strange that, as i always prefer an electrical coax connection.
  13. sc1977
    sc1977
    Jul 16, 2002
    600
    kent
    +8
    there may not be a dedicated coax for dvd but the RF and digital coax on the 3090 are 2 different inputs
  14. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    You can use the coaxial CD input for DVD, too. I don't think it matters if the input is called CD, DVD or else. :)
    There was no DVD around when the 3090 was developed. I nearly bought one but the DSP-A1 had just been announced and I went for that, mainly because of the 5.1 input (and it had DTS decoder, too, the first at the time).
  15. Ryan288
    Ryan288
    Thanks everybody for thier advice, I have managed to sort out my problem. I am enjoying my DVD collection now that I can have Digital surround.
    :clap: :clap: :clap: :clap:
