cunnas
Hi all
Thanks for all your help when I was asking what kind of system I should go for. I eventually went for a Pioneer DV565 DVD player, a Yamaha DS-PAX640SE Amp and a set of Enery Take 5.2 speakers.
Anyway, I have a bit of a dummy question. I've got everything set up and working, with the DVD connected to the optical DVD port on the Amp. I select the Amp input as DVD and everythings fine but I'm not sure what the best setting is to use. The Amp uses all these DSP things that I've read about and the default one is something called Enhanced which I've been using it on. The only setting which does't use DSP is Dolby Digital/Pro Logic but I'm starting to wonder if thats the best one to use. What happened to Dolby Pro Logic II etc? On my old Sony system the DVD used to display Pro Logic II etc if thats what the DVD used.
I might be completely wrong and be talking utter balls but am just after bit of advice!
Tim
Tim
