I have to read the manual and figure out how to bump centre channel when needed.
Do you use AI?
When I turn on the AI also DSP lights up on the display - if I have all DSP turned off in the settings it means nothing that it lights up am I right (other that of course AI function is a form of DSP).
Thanks for starting this thread mate
it's about time it had some limelight
Absolutely, about time
I’m very happy with mine - superb SQ and the build quality is excellent as usual from Yamaha. Not much else to say really - no issues to report, no firmware bugs etc.!!
It is early days so far for me but also very happy. I like that Yamaha tend to be able to create sounds not attached to the speakers so perceived as emanating from space rather then from membranes.
Also so far everything works as afvertised altough I have not checked almost any functions at all. I have not even run YPAO yet. How do you find it guys? Is it bringing worthwhile improvements? Does it not muddy up the sound like Audyssey tend to do (loss of resolution and air suck-out with Audyssey was staggering in my experience).
I did call Yamaha UK before I purchased this back in the early summer and ended up speaking to one of their engineers. He advised that a new pre-pro was not scheduled for release until Q3/4 2021.
Great info and nice to hear. I do not care about 8k (I think) so the only reason for me to change to different Pre is when and if I will be ready to change to 16 channels with 9.x.6 config. Or when some more important changes them 8k would come along which I would really like to have.
I also looked into the rising THD&N issue on the L&R XLR output over 2V as raised on Audioholics. I calculated that with my speakers and power amps I’d only realistically ever need 1.1V so this ended up being a non-issue for me. This is enough to hit approx 108dB - plenty loud enough. I can share an Excel spreadsheet that I put together to calculate this if anyone else wants to check their own configuration.
Please share your Excel if you can, it would be interesting to see.
I use (high efficiency) L + R with 2 channel amp which reaches its max power at 2v so should be ok as well. I have them connected over XLR as cable run is about 15m.
