Yamaha AX750SE lip sync?
Discussion in 'Plasma TVs Forum' started by giantteabag, Oct 12, 2004.
  1. giantteabag
    giantteabag
    I'm thinking of getting the 750 to replace my Sony DB940 when I go from CRT to a Panny 42" PW7, in order to pre-empt the lip sync problem.
    My questions are as follows:
    1.Does the 0-160 ms lip sync function work?
    2.How do you adjust it..can you do it on the remote?..how easy is it given different content has different delay issues?
    3.How good is the svideo to component conversion?
    4.I have sky+ & intend to output svideo to 750, convert to component & send to the plasma. Is this picture better than taking rgb from sky+ & converting it to VGA using a JS Technologies box?
    Thanks.
