Yamaha AX1 - Room Size Settings
lutonian
Hi All,
has anyone ever setup their AX1 with the Room Size settings ? I would just like to know if the 0.1 - 2.0 settings refer to feet/meters or something else.
sacd
I did'nt think the AX1 had room size settings, I will just go and check!
sacd
Hi, look on page 44 in your manual. 1ms delay = 30cm (one foot)
Hope this helps.
sacd
I have the manual on pdf if you want it e-mailed to you.
lutonian
thanks sacd, i will give this a try over the weekend and give you a shout if i'm still stuck.
Similar threads
