Yamaha AX1 and THX speakers.
Discussion in 'AV Receivers & Amplifiers' started by ilkand, Oct 22, 2003.
Tags:
  1. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    I have just bought (I hope) a Yamaha AX1 and some KEF THX speakers. Since the small setting on the Yamaha is 90hz, will I lose sound quality using these two together. Or is there a good way to set them up? Should I have gone for an AS10SE instead?
    Andrew
  2. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    They'll be fine. You won't lose sound quality, it just means the crossover frequency is 10hz higher than it would be with the Denon (80hz).
  3. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    Cool, I just wondered (since thx set 80hz), if this was the very best setting and everything else was somehow not as good.
    Will I lose any other functions with a non-thx amp? I read once that the avc10se does something to the rear centre to make it very slightly different. Is this useful?
    Andrew
  4. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    What about if I added the audigy thx soundcard to my htpc and used the yamaha amps instead? Would this be a good idea?
    Andrew
  5. Smurfin
    Smurfin
    Aug 13, 2002
    20,639
    +4,002
    Best asking that question in the HCPC section....
  6. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    THX amps and speakers are designed to work together but you don't have to match a THX amp with THX speakers, each will work with non-THX certified equipment.
    You'll lose THX Post Processing (for info see www.thx.com ) but whether you like this or not is down to personal taste, some like it, some don't.
    The Denon A10SE has THX Surround EX processing but only five channels of amplification so you would need the extra two channel power amp (POA T10). The Yamaha has it's own form of matrix processing to extract info for the rear centre speaker. Both achieve the same results at the end of the day i.e sound coming from behind you. :)
