Yamaha AVR 1070 /Epson TW7400 HDMI dropout frustration
highly_defined
Established Member
Joined
Apr 24, 2006
Messages
280
Reaction score
17
Points
91
Hi all. I replaced a Sony STR DN1080 with a Yamaha AVR 1070 as I needed the ability to change HDMI sources with the amp turned off. However, I'm having an issue with HDMI output to the projector. I never experienced any dropout with the Sony amp but whichever source I use I'm getting 2 or 3 dropouts close together after anywhere between 90 minutes and 2 hours of running. The projector is using HDMI 2 out from the AV Amp (my TV is using HDMI 1 ARC). I have tried swapping out the HDMI cable (it's 15ft from amp to projector) - changing my expensive optical HDMI to a standard one has made no difference. I'd really like some advice on what to try next, a logical troubleshooting path would be most helpful, thanks.
Ain’t sure if you fixed an issue , but I seems had same issue with my. 7400 and denon 2600 . Now my hdmi 1 does not work at all. Assume it was some motherboard fault . I will contact epson to pick it up as I luckily bought 5 years rtb warranty .
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
