YAMAHA AV 59 - is it good & how does music sound on it?
Discussion in 'AV Receivers & Amplifiers' started by mailesan2007, Apr 28, 2007.
Tags:
  1. mailesan2007
    mailesan2007
    need help, planning to buy Yamaha AV (RXV 359 +NSP 110),
    how is sound quality & can i use this for listening to music like any stero system
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    I'm not sure about availability now, so you might not be able to actually get one.
    Judging by my 557, it should be ok for listening in stereo.
    It depends what you're used to.
    It's probably on a par with your average £150 stereo setup, at a guess.
  3. dor146
    dor146
    The amp is probably ok, but the sats are prob only ok for movies. You could get a couple of half decent bookselves for music and use the A/B switch.
  4. mailesan2007
    mailesan2007
    hi i just bought yamaha RXV 359 + NSP 110 ( AV 59) but the problem is that rxv 359 get heat's up fast and power goes off. can anybody help me
  5. mailesan2007
    mailesan2007
    can you suggest me any speaker good for this amp
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    Are you running it flat out?
    It shouldn't cut out at all.
    Most speakers should be fine
