Yamaha AV 50 - Yamaha RXV350 + Yamaha NSP100 5.1 Loudspeaker package.
Discussion in 'AV Receivers & Amplifiers' started by andrew_w, Dec 16, 2004.
Tags:
  1. andrew_w
    andrew_w
    I'm thinking of purchasing this package to compliment a DVD recorder
    that I've just brought.
    The trouble is I'm fairly new to all this, I had a look round for
    reviews for these models but I can find nothing of use.
    So the question is, are these any good?
    Any and all advice appreciated.
  2. mjkinch
    mjkinch
    Dec 16, 2004
    48
    Nantwich
    I hope youget a good response, based on previous threads I have just purchased the same package for my Christmas present. I got it from www.unbeatable.co.uk . I will let you know how it goes if you are still looking after Christmas.
    Best of luck
    Martyn
  3. Joshie76
    Joshie76
    I've been looking at this unit myself (great price on that site!). What's it like? Would you recommend it?
  4. internetuser
    internetuser
    Jul 17, 2003
    3,433
    +247
    I fancy this too, it looks nice a decent budget set up. if only it had component out and 6 or 7.1 on the amp. (yes I am dreaming, at this price it seems to be a steal)
  5. Shippo
    Shippo
    Jan 17, 2004
    15
    North West
    Did any of you guys buy this package?
    I'm after a budget system and this seems ideal.
  6. internetuser
    internetuser
    Jul 17, 2003
    3,433
    +247
    I got this, its very very good for the money.
    Can not really fault it. I upgraded from a DigiTheater DTS to this and it blows it away.
    Amp is a bit complicated, but you expect that.
    I ordered on wednesday lunch time and got it the next day at 11:30am via city link.
  7. Roachman
    Roachman
    Jul 11, 2004
    199
    Leicester
    +6
    I bought mine from Unbeatable just before Christmas and I'm very happy with it.
    Had a bit of a scare when I first connected everything up because I couldn't get any sound out of the rear speakers :mad: I think I had the speaker output set to B and it should have been A (or something) :D
    Used mainly for dvd's and X-box, occasionally use the tuner too for local radio.
    A couple of things struck me when I unpacked it from the huge box..
    1. How big it is - I just wasn't expecting it to be that big. :eek:
    2. How many flippin' connectors there are on the back. :eek:
    I'd recommend it to anyone who is looking to get into "cinema sound" and doesn't want to spend a fortune. :thumbsup:
    Hope that helps.
  8. mjkinch
    mjkinch
    Dec 16, 2004
    48
    Nantwich
    I got the system over Christmas, and as someone pointed out, it is a BIG box of stuff. All went together really well, and worked first time. The Yamaha speakers are great and work fine for me, I am not a specialist in this area, so am happy with the quality all round. For the price is certainly was better than anything else I could find of comparable spec.
  9. Ace T
    Ace T
    Sep 17, 2003
    349
    Watford
    +3
    Very close to ordering this pacakage...any more feedback on it would be appreciated?? Anyone ordered the AV75 or AV100 packs?
