Special K 2
These questions apply to UK equipment
I have just taken delivery of a Yamaha as801 amplifier from yourselves.
I wonder if you could confirm something.
The amp has a impedance selector switch, it is currently set to high.
I am running one pair of speakers that are 6ohm impedance, and according to the instructions for speaker set up A or B
6 and 8 ohm should be set to high, but in brackets it says Asia models Only
Then it says 4ohm and higher set to low.
Could you confirm which it should be as I am a little confused as my impression it should be set to 4ohms and ie low,
so that would require a change of the switch fro where it is, correct?
Chris
Chris
