Yamaha Amps?
Discussion in 'AV Receivers & Amplifiers' started by weyland-yutani, Sep 23, 2003.
Tags:
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    Do they all insist that your dvd player be connected by the optical socket?
    Can you change it so the amp calls the coax connection 'DVD' not 'CD'? That's damn annoying, if you can't.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,154
    2
    +3,588
    They are very heavily configured for optical use but the Coax can be configured for DVD use after a bit of fussing. I don't recall being able to change the name though.
  3. sdh500
    sdh500
    Yes, weyland-yutani, you can fix it so that your amp does just that. Find the bit in your manual on I/O (input/output) assignment. The Coaxial input jack is initially set to CD but once you change the jack assignment it will think it's a DVD jack. You must then go to the part called Input Rename and change CD to DVD.
  4. avanzato
    avanzato
    Jan 21, 2003
    1,954
    Norfolk
    +77
    On my AX630 all I needed to do was assign the coax digital input to the DVD. No need to rename.
  5. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
