Yamaha A2 mod?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by VirusKiller, Jul 4, 2005.
  1. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    Anyone modded or know if it is possible to mod a Yam A2 to get direct access to the 3rd, 4th and 5th channel power amps directly? (as you can do with the main L/R channels).
    Using the 5.1 input, you have to go through a lot of circuitry including the volume control. This adds noise and if you knock the volume control, you lose calibration.
    Joel
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    Never heard of that one.
    Tbh, I'd have thought a 2nd hand power amp would be a better/cheaper option?
  3. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    Yeah. The way this hobby's grabbed me at the moment, it'll be a pair of Meridian amps to boot, albeit "entry-level" 555s. £££ Sigh!
  4. recruit
    recruit
    Joel i have a G55 you could buy if you're interested :devil:
  5. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    Thanks recruit, but I'd just hate wasting that 5th channel. :D
