Hello folks,
Im after a critique of my proposed 5.1 set up, if you please?
room is 5m x 4m with 2.4m ceilings - Glass doors run the length of one of the side walls, which i intend to put up curtains
Receiver:
Yamaha a1050 (although considering just going for the a850 - waiting to see how DTS:X pans out - also considered the Marantz nr1606/SR6010, but there's just no reviews on the 1606, and the 6010 design just isn't doing for me.)
Speakers:
FL/FR - B&W DM302 (these are a stop gap until i can upgrade to some MA Silvers)
Centre - MA Radius 200
Surrounds - MA Radius 90s
Sub - REL T5
Use will mostly be for movies, but some musicality is important to me, although this will predominantly be supplied through Sonos, so audiophile quality expectations are well and truly managed…
Aside from my legacy Fronts, does this look like a good combination? are there any specific elements you would tweak?
I understand that the speakers are perhaps 'underselling' the quality of the amp, but i can only sink so much cash in one go…i recognise there will be an ‘on going’ upgrade path, but thats the fun bit, right?!
Thanks for your help/advice
Sparra
Receiver:
Speakers:
Sub - REL T5
Sparra
