Yamaha A/V Amp owners !!!
Discussion in 'AV Receivers & Amplifiers' started by RobG, Feb 19, 2001.
Tags:
  1. RobG
    RobG
    Has anyone used the 'manufactuerers codes' to turn the remote into a multi-remote?
    I have a DSP-A5, which says I can use the remote for my TV(Samsung), DVD(wharfedale), Cable(Pace), Video(sanyo) etc, etc.
    I'm getting tired of trying to figure out which remote I should be using - where do I get the codes from ?
  2. Stick
    Stick
    Rob,
    All the codes you need are in the back of the instruction book,(er, I mean Novel!!!-its a bit heavy!!)-be warned-it it's very laborious programming each one in turn, especially when you find that the code you have entered only works half the controls!!.
    Great Amps these, I'm well impressed with mine:)
    ...."They're maggots Michael, you're eating maggots"....
  3. RobG
    RobG
    Doh!
    I only read the first 1/125th of the manual, as I assumed all the rest of it was for the United Nations..... will check when I get home!
    Cheers,
    Rob
