yamaha 750 set up without a sub - sub now added - help please??
Discussion in 'AV Receivers & Amplifiers' started by samjet, Feb 4, 2005.
Tags:
  1. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    as it says when i set up my 750 a few weeks ago i did not have a sub - used the microphone to 'balance' the system and worked fine
    UNTIL NOW
    i have just added a REL storm sub and i'm getting nothing from it
    does the problem lie in the fact that the original set up noted no sub and does not accept that ones been added??
    am i best to restore factory settings and repeat the set up process from scratch again using the mike etc
    thanks in anticipation
  2. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    117
    16
    Have you re-run setup again with the sub added?
    Andy
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Try re-running setup and then manually check your settings. Also, try to find out what your crossover is set at.
  4. imichael
    imichael
    Nov 5, 2004
    209
    16
    West Sussex
    If you had no sub on auto set up all the LFE signals are going to your front speakers. Either run auto set up again, or go in to manual set up and change LFE to 'both' or 'sub' and then check your subwoofer crossover frequency (max on the sub and usually 80-100 on the amp).
  5. Jackam
    Jackam
    Doesnt the LFE input on the REL bypass the xover frequency?
