yamaha 675 or 575?
Discussion in 'AV Receivers & Amplifiers' started by sim12, Feb 2, 2014.
Tags:
  1. sim12
    sim12
    Jan 5, 2014
    610
    43
    +212
    looking to upgrade my old onkyo 506 , was looking at the yamaha 675 , but also caught a thread on the 575 , look at the comparison chart and there does not appear to be much difference . I not interested in wifi of bluetooth or upscaling to 4k , so take them out of the running , sound wise would
    i hear a difference between the two , Any feedback would be great thanks.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    What speakers do you have?
    I doubt you will hear that much difference (if any) between the 2 models you mention.
  3. sim12
    sim12
    Jan 5, 2014
    610
    43
    +212
    the speakers i have are only budget ones nothing special , i kind of thought that there would`nt be much if any thing in it with the amps. cheers.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    If you have budget speakers then most likely will not hear any difference. Probably better to get the 575 and use the money saved to put towards better speakers.
