Yamaha 650/750 owners - help?
Discussion in 'AV Receivers & Amplifiers' started by steve 111, Aug 2, 2004.
Tags:
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Just linked up my new RXV650 to a Denon 2200 using a digital coax cable only and when playing Gladiator it fails to auto detect DTS. Anyone else experienced this DTS encoded DVDs? If so, how did you solve it?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    None of my dvd players or amps auto detect DTS unless I choose to use it in the audio section of the dvd.
  3. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    My 650 automatically recognises DTS soundtracks including the one on Gladiator once the correct soundtrack is selected on the DVD - R2 Gladiator defaults to the English Dolby Digitlal soundtrack.
    Hope this helps
    Chris
  4. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Chrise,
    So do I select DTS from the disc menu, or on my DVD players menu?
  5. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    On Gladiator wait until the main menu has loaded go to Languages/audio option and select there. You will see a short DTS trailer - a grand piano. If you watch the amp you will see it switch to DTS for the trail away for a warning screen and back for the film itself.
    Some discs can allow you to select soundtracks directly using an audio options menu on the DVD player but Gladiator does not allow that on my player.
  6. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Thanks for that. Do you know whether doing this is unique to Gladiator, or do you need to do this on other DTS encoded films?
  7. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    Newer films (eg The Two Towers and Master and Commander) allow selection of the soundtrack directly. Gladiator is in DVD terms an old film and one of the first I have with a DTS soundtrack on a R2 disc. I have never seen a DVD to default to DTS rather than Dolby Digital tracks but I suppose there maybe some that do.
    You can always select any DTS soundtrackfrom the disc's own menu usually, through the language option.
  8. oliver24
    oliver24
    Steve,
    I have the same amp as you and am thinking of getting the Denon
    2200, And I would like to hear how your getting on with your set up??
    Regards
    Oliver
  9. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Oliver,
    The 650-2200 combo is excellent. The only issues I have had so far are:-
    2200 occasionally vibrates hugely when playing DVDs, have live post on here to see if this is common place.
    650 volume needs to be cranked right up (-20dB +) for movies
    If I was sticking with my Kef Eggs I wouldn't bother with the 650 as it is over speced in my opinion for those speakers. Once I get my M&Ks however it should be perfect.
  10. Radiohead
    Radiohead
    Dec 24, 2001
    4,392
    Amazingstoke
    +432
    I don't agree that the 650 is overspecced for the KEF's at all.
