Yamaha 640 SACD or DVD audio
Discussion in 'AV Receivers & Amplifiers' started by briggsy, Jan 15, 2004.
Tags:
  1. briggsy
    briggsy
    Jan 10, 2004
    54
    I'm a bit confused on how to connect SACD to my Yamaha 640. I don't think I can connect an SACD player to it. Is this true.
    I assume DVD- Audio comes through the optical connection.
    But how do you connect an SACD player to it ? I don't think it has a 6 channel input, only output.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    If your Yamaha does not have the 6 analogue inputs then you cannot get DVD-A or SACD into it. Both the multichannel formats need the analogue connections as the decoding is always done on the player and not in the receiver. The only exception to this is the new Pioneer receivers & DVD players that have the iLink interface.
    It's not all bad new as if you can play DVD-A then you can still get a DD/DTS multichannel mix that does get passed to the receiver by either optical or coax. I'm not sure if this is also true of SACD or not.
    Mark.
  3. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    I am pretty sure your Yamaha 640 has got the 6 channel input required.
  4. marillion
    marillion
    Sep 29, 2003
    89
    11
    +4
    the yamaha 630 definately has 6 channel input so i presume the 640 does as well
  5. briggsy
    briggsy
    Jan 10, 2004
    54
    Sorry everyone.
    It does have 6 channel input I am a complete idiot for not noticing.
    for you help
