yamaha 630rds upgrade under £500
Discussion in 'AV Receivers & Amplifiers' started by danfrance110, Dec 31, 2003.
Tags:
  1. danfrance110
    danfrance110
    Hi all,
    Looking to upgrade my current receiver, a yammy 630rds to something a little more powerful and upto date. Currently have B&W 603s3, lcr600, 600s3 and asw650 speakers which I have no intentions of upgrading in the near future as I am very happy with them. Looking to spend no more than say £500 unless there is a significant jump in performance for a little bit more cash. Also not really worried about 7 channels of amplication, 5.1/6.1 is all I need and I don't mind buying second hand if there are some good buys out there.Looking at a couple of sale items in my local superfi saw a sony va555es and a yammy 740rds for under £500 which looked like good buys. Any opinions would be much appreciated.
    Dan
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    I'd definitely recommend the Sony 555 you saw at superfi - that's one hell of an offer they've got (you can buy it off the web too).
    You might want to also try a Pioneer VSX-AX3, which sells for around £599. And Denon's 2803, which sells for around £450, although isn't in the same league as the Pioneer or Sony.
    I wouldn't recommend the Yamaha, simply because I hate the aesthetics of Yamaha receivers, and wasn't overly impressed with the sound quality (although it was good).
