Yamaha 630 Remote codes
Discussion in 'AV Receivers & Amplifiers' started by JayBee, Dec 18, 2002.
Tags:
  1. JayBee
    JayBee
    Oct 22, 2002
    Well I've just received my first AV amp - Yamamha DSP-AX630. Not had a proper chance to give it a thorough workout yet (didn't finish setting it up until 10pm), but it all sounds good so far :D
    Anyway, the remote is one of those that allows you to enter manufacturers codes to control other devices. I was wondering if anyone knows of a code that work with the LG-2330 DVD player.
    Also, I assuming that the remote won't work with my Telewest cable box, due to the fact that it's one of those models that use a different IR system (4000 model I think). If this isn't the case, then does anyone know of a code for that as well.
  2. Lucky Scotsman
    Lucky Scotsman
    Simmilar question to the one that I was about to ask.
    I just replaced my RXV430RDS with an RXV630RDS and would like to utilise the multi-functional aspects of the remote, but the manual does not mention any LG products.
    For me, it's the LG 3200E
