yamaha 630 and banana plugs?????
Discussion in 'AV Receivers & Amplifiers' started by Adrenochrome, Mar 9, 2003.
Tags:
  1. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    is it possible to use banana plugs with the yammy 630??
    if so can someone tell me how to do it as i'm stumped:eek: :eek: :confused: :rolleyes:
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    just (carefully) make a small hole (I used a very small screwdriver) in the centre of the red plastic bung then push the banana plug into the hole
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    cheers wilber brute force won in the end as i just got a wee bit angry and pushed the wee b right in :smoke:
  4. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    There are actually covers on the binding posts which come off, revealing the holes for the banana plugs.
    I just levered them off with a small screwdriver (IIRC, there is a tiny hole in the cover, just use that to lever them off)
  5. konghh
    konghh
    Blame it on the EU regulation ban against banana plug. Since you remove the plug cover, it's now none of yamaha's responsibility.
  6. Sheepdisease
    Sheepdisease
    Jan 26, 2009
    287
    +4
    What are banana plugs and what's the problem with them?
  7. ChrisAV
    ChrisAV
    Dec 5, 2008
    763
    43
    Wirral
    +110
    This is an example of a banana plud Banana Plugs with Gold-Plated Contacts > Maplin
    They connect to the end of your speaker cable, sometimes screwed but there are other methods. So instead of fiddly bare cable to insert and tighten in your amp, you have a simple connector to plug in.
    The only issue really is amps usually ship with small blanking plates you cover the holes on the amp, and they are not always obvious, giving the impression that the amp doesn't accept banana plugs.
    Chris
