Yamaha 620AX - On Screen Set Up???
Discussion in 'AV Receivers & Amplifiers' started by Lester's Cloud, Mar 31, 2002.
Tags:
  1. Lester's Cloud
    Lester's Cloud
    Small annoying problem....... please help!
    I have Yamaha DSP620AX amp and Pioneer 626D DVD player. These are connected directly with high quality SCART.
    I have my cable TV and video connected to the last remaining SCART on the TV.
    The amp is not normally connected up to the TV for video input as I don't need it to do any switching, just audio.........
    So - the TV has one last input, a s-video input on the front. I was hoping to connect the s-video TV input with the amp s-video output using a common or garden audio cable........
    When I do this the on screen set up appears, however it floats all over the screen and is very hard to use.
    I have tried removing one or both SCARTs when connecting the s-video but this doesn't seem to help.
    Do I need a different cable (remember I only need this to set up, not watch video through) or is there an easy solution.......
    Thanks,
    Lester's Cloud
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Are you sure it's s-vid? Or are you connecting via composite, if you're using what I assume is a standard phono cable? Make sure all other inputs are switched off and cycle through your AV channels.
    What do you mean by 'floats all over the screen'?
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    If you have a phono video input on the front of the TV a single phono from Monitor Out to this input should do the trick. It does on my Marantz.
    As it is not connected permanently I just disconnect one of the other leads and use that.
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    That's what I do with my 620, and I'm assuming that's what Mr Cloud is trying to do as well...
  5. Lester's Cloud
    Lester's Cloud
    Not quite sure what I was doing wrong, but it's all cool now, like three little fonzies.........
    thanks all.:D
