Yamaha 620 probs !
Discussion in 'AV Receivers & Amplifiers' started by blackcat, May 18, 2003.
Tags:
  1. blackcat
    blackcat
    May 11, 2002
    19
    north-east england
    While listening to Audio in surround mode, I have an irritating "interference" sound coming from my speakers, but if i change to "effect off" mode it dissapears. Could it be my speaker wire connections? this problem has only just occured, the Amp is 12 months old. Anyone with any ideas ? Thanks in advance.:confused:
  2. JFK
    JFK
    Apr 6, 2002
    209
    middlands of no return
    +11
    Which speakers is it coming from? What volume is it at (on screen of amp) when you can hear the noise? While listening to audio, is it CD or is TV & DVD aswell?
    Turn all equipment off but amp and turn volume upto -25db on screen and have it selected to dvd in normal prologic surround mode, is there a electrical current crackling noise coming from the tweeters of the main left & right channels?
  3. blackcat
    blackcat
    May 11, 2002
    19
    north-east england
    Hi JFK,
    While in Dolby Pro Logic, Dolby Digital surround mode with the amp ONLY switced on, it has the crackling noise coming from the tweeters like you said at around -25db. While in "effect off" mode it is as clear as a bell !
    Any ideas Jfk ? Is my amp faulty ? and if so does Yamaha products have a standard 2 yr warranty , as its around 13 months old .
    Thanks for your help.
