Is it normal for these beasts to generate a lot of heat...??
Its almost too hot to touch on the top... Ive only had it on for a couple of hours on a very low volume, listening to footy on the radio....
I cant believe it is generating so much heat, its like a radiator... you can feel the heat eminating up through the vents...
Having not owned a decent bit of hifi for a while, im unfamiliar with what is normal, I would have at least expected a fan in there like my old technics amp many moons ago....
