Yamaha 2500
Discussion in 'AV Receivers & Amplifiers' started by stvn, Jan 8, 2005.
Tags:
  1. stvn
    stvn
    Anyone knows if Yamaha 2500 have an FM outdoor antenna connection.
    Reading in internet the specs and the manual I think no have this connection.
    Is important for me because where I leave the FM reception is no very good with an indoor antenna
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    The RX-V2500 does have a connection for regular coaxial antenna cables. The connection is not a special design in any way, the included indoor antenna wire merely connects to the center prong and you are not limited to using it.
  3. Benrudd1
    Benrudd1
    Jan 19, 2003
    942
    Pembroke Dock
    +66
    According to the picture from the Yamaha website, here ,it has a standard rf socket for an external antenna.
    Hope this helps
  4. stvn
    stvn
    Hi.
    Now I saw it.
    Thanks for all.
