Yamaha 2500 Auto Setup
Discussion in 'AV Receivers & Amplifiers' started by betamac, Dec 22, 2004.
Tags:
  1. betamac
    betamac
    Well i received it today and ran auto setup
    seems to have set things up totally differently to the 1400
    I Use Kef Q7 Fronts, Q1 Rears And PSW2500 Sub
    Its set the fronts and rears to large and set the crossover to 200
    On my 1400 it set the crossover to 80 ? abit of a difference although sticking on Lion King Enhanced HT Mix it sounded amazing so maybe its for the better?
    Also a slight niggle it says my front left and front right are out of phase i have checked the cable and as far as i can tell they are plugged in the right way round shall i just ignore this or change them round so it thinks there ok?
  2. recruit
    recruit
    I would not worry about it the Auto setups tend to get things wrong as long as you have physically checked they are ok then good enough.
    I would change the Xover though 200 seems way too high especially for the Q7's.
    John
  3. Poolsharkie69
    Poolsharkie69
    I have the 1500 and the auto setup was a bit off for me. Can u tell me what the onscreen GUI looks like? I just got my 1500 about 2 weeks ago and read on this forum that is one of the differences between the 2 receivers. Thanks
  4. betamac
    betamac
  5. Poolsharkie69
    Poolsharkie69
    80 is THX rec. I have mine set that way and it seems to sound fine. My specs are in my sig...i also just posted a thread with my full specs a few moments ago. Damn I like that interface...not sure if that is enough for me to upgrade already to the 2500 I have only had the 1500 a week or so. I think there is a large price difference between the 2 as well.
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,822
    London
    +1,091
    200 does seem high set it below 100 imo.
