Yamaha 1500 power lead?
Discussion in 'AV Receivers & Amplifiers' started by sillybeans, Apr 27, 2005.
Tags:
  1. sillybeans
    sillybeans
    I've just bought one of these from Germany and it has what looks like a standard kettle lead connection. Should I reuse the original cable and swap the plug or just use a pc cable? It says in the manual to swap the plug.
    Mike
  2. ehayde
    ehayde
    Sep 21, 2004
    4
    Chippenham
    Hi Mike
    Personaly, as long as the "kettle" lead is IEC approved for the UK, I wouldn't hesitate to use it myself. Try and keep your power cables for the Yammy 1500 and the rest of your peripherals together and away from interconnects.
    cheers
    EJH
  3. sillybeans
    sillybeans
    Thanks. Standard cable works a treat. The supplied cable was marked L+N which was handily also marked on my pc cable! Just got to wade through the rather large setup manual now :eek:
    Mike
  4. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    just got a 1500 myself mike and i think it sounds awesome and once you get used to it very easy to setup
  5. sillybeans
    sillybeans
    It does sound great, but it's taken me ages to get set up. I've found that the only way to get the rear surround speaker to work properly on sky+ sources is to use PrologicIIx Movie.
    One problem I do have (but not major) is the svideo upconversion to component from sky+ svideo output gives black and white on my toshiba. When I plug the sky direct to the svideo on the tv it works fine.
    Any ideas?
    Mike
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Might be some sort of macro protection, does your tv work ok with component form a different source? Also you are leaving your sky + on svideo? as if you change it to rgb it may not work properly.
  7. sillybeans
    sillybeans
    Cheers for the reply. I tried removing the scart cable and switching off the rgb with no luck. All sky channels are affected, but direct svideo to the tv works and my Denon 2800 works fine with component output to the tv.
    I think I'll have to get a rgb to component converter for the sky. More money! And I've just dropped my rear speaker. It works but something is loose!
    Mike
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Your tv is using RGB or component, from the amp?
    Are you going sky(RGB with converter to Component) -> amp -> tv (Component)
  9. sillybeans
    sillybeans
    Currently
    DVD (Prog Component) -> Amp - > TV
    Sky+ (RGB Scart) - > TV
    Will probably change Sky+ output using one of the keene rgb to component converters as you describe. I am also wiring up for a projector (cheaper end so will be using component input again) and will need to add a switch after the amp. I'm pretty sure this is the best route.
    Mike
  10. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Try composit from the Sky to the reciver, i think most sky boxes don't have an s-video out, so without an rgb->component converter thats the best your gonna get.
    Have you tried putting just s-video from the reciver to the tv, i.e.
    sky (s-video) -> reciever (s-video) -> tv
  11. sillybeans
    sillybeans
    Will try that, but think that the converter is the only way to go. Can't stand the PAL image that the composite would give!
    Thanks for your help.
    Mike
