Yamaha 1500 - do the feet come off ??
Discussion in 'AV Receivers & Amplifiers' started by Boozyuzi, Jan 23, 2005.
Tags:
  1. Boozyuzi
    Boozyuzi
    Aug 10, 2002
    557
    Edinburgh
    +35
    Can anyone tell me if you can remove the feet from the Yamaha 1500 receiver ??
    Thanks.
  2. LITTLEBRITAIN
    LITTLEBRITAIN
    Nov 28, 2004
    310
    19
    Greater Manchester
    you can mate but it wont last very long!
    you cant remove the feet from any amp etc as there needed for cooling. ie air goes in the bottom via heatsinks etc and out comes toasty air!hehe
