Yamaha 1400
Discussion in 'AV Receivers & Amplifiers' started by IVOLIC, Aug 28, 2005.
Tags:
  1. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    I have had the amp for over a year now but there is something I just can't figure out! :rolleyes:
    When I have the amp set to direct stereo the display starts to dim after about 3 seconds. When something is changed on the amp the display somes up to its "set" brightness and dims again. This does not happen on any other surround option. This does not bother me but I would like to know why is this and if I can use it on other surround settings. I can not find any info in the manual or through the amps menus.
    Is this normal???
  2. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    The display off bit is a feature of the direct stereo sound. The idea is that as little as possible is going on in the amp, including lighting up the display. So to make it not look like it just dies, they have it fade away. Then when you change something, volume say, it's nice to know what you're doing, so it goes back on again. For a while. Perfectly normal.
  3. szd
    szd
    Dec 4, 2000
    330
    2
    Gloucester
    +15
    I've got the Yamaha 1500 and mine does the same, turning off the display eliminates any interferance that it may cause, allegedly.
  4. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    I thought that maybe something like that was the reason but it seems a bit overkill to me since the display does not go completely off. :rolleyes: There would still, in theory, be noise that can interfere with the output.
    I was hoping that I missed something in the manual so that I can apply this to DD or DTS modes. :)
    This option is the same as my Denon DVD. You supposedly turn off the display, in pure direct mode, but I can still se power going through the LED display inspite it being "off".
    Thanks for the replies! :clap:
  5. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    you can do it to all modes. Its mentioned in the manual on page 58 under manual option:select dimmer. :lesson:
  6. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    REALLY????? :eek:
    Can't wait to get home then! I also can not believe I missed that!?! :suicide:
  7. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    Well I tried to find this option last night but to no avail. :mad:
    Either the option doesn't exist or my model does not support this option. It is not stated in the manual nor in the amp's menu.
    :hiya:
  8. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    Set menu, option menu, dimmer. It's in your manual.
  9. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    Sure I know that but all I can set is the brightness of the dimmer 0-4, if I remember correctly. What I am trying to say is that I can not set the dimmer to say 4 (bright) and have it automatically turn down after a few seconds (as in the direct stereo mode).
  10. blasthand
    blasthand
    May 29, 2004
    242
    Yateley, Hampshire
    +11
    Ivolic,
    I have the Yamaha 1500. When I listen to cd's I put the amp into 'pure direct' mode, which sounds kinda similar to your direct stereo. When my amp is in this the display panel on the front goes off completely, but comes back on if you turn the volume up etc...it's normal for the mode on mine, sounds like yours is just doing what it should if it is similar to the 'pure direct'. I wouldn't worry about it...just enjoy ya tunes! :thumbsup:
    Cheers,
    Mark.
