Yamaha 1400 - Progressive scan ?
Discussion in 'AV Receivers & Amplifiers' started by serdar13, Jan 20, 2004.
Tags:
  1. serdar13
    serdar13
    May 19, 2003
    90
    I was wondering if I use component out of a Toshiba SD530 (which accepts NTSC/PAL PS) into the Yamaha 1400 and out of the Yamaha into a Toshiba 42wh36 RP (which accepts NTSC/PAL PS), if the yamaha will transfer the progressive signal.
    I haven't received the amp but wanted to sort the cabling out.
    Any help will be appreciated.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    The '640 does so the 1400 should as well.
  3. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    What are the benefits of this versus going straight from your DVD player to your TV?
  4. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Key benefit for me is that the projector can use just one input and everything goes through that. This way I just leave the projector on Component and everything is scaled up that isnt component.
    On the down side the quality must deteriorate slightly if going via amp rather than straight to viewing device?
    Tone
  5. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    So are you saying you can plug everything into your amp (DVD, Sky, etc.) and then have just the one component input into your display?
  6. bobgriffiths
    bobgriffiths
    yes he is saying that and yes the Yam has the ability to pass prog scan component signals see the pdf on yams web site
  7. serdar13
    serdar13
    May 19, 2003
    90
    Has anyone tested component from dvd via amp to tv/projector and going straight from dvd to tv to see if it the image does get degraded?
    I assume the better the amp the better the throughput should be.
  8. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    If you go from your DVD to Amp with an S-Video lead and then have the component lead from Amp to TV, am I right in assuming you the PQ will be 'S-Video' or does the Amp do something to upgarde the image to 'component' quality.
  9. serdar13
    serdar13
    May 19, 2003
    90
    I have read the manual and if your source is s-video or composite and you are up converting to component then the image will only be as good as the source so wont be better.
