Question yamaha 1065
Discussion in 'AV Receivers & Amplifiers' started by THE BOARS, Jan 13, 2017.
Tags:
  1. THE BOARS
    THE BOARS
    Nov 25, 2004
    4,190
    68
    +98
    hi there ,i have the above amp and just bought a new tv unit [like a tube i didnt check the size] and to cut a long story short ,it dont fit .
    Is there such a thing as slimmer amp,s and are they still of a decent quality ,i only have around 5 inches to play with [jokes away ]
  2. THE BOARS
    THE BOARS
    Nov 25, 2004
    4,190
    68
    +98
    Marantz NR1506 ???Yamaha RX-S600
  3. dante01
    dante01
    Mar 5, 2009
    45,846
    +10,954
    Yamaha RXAS710
    Marantz NR1606
    Pioneer VSXS520
    The slimline models do tend to be less powerful than the more conventional designs. The slimline models are targetted more towards the lifestyle market than towards the dedicated home theatre market. You'd more readily use one of these in a second ancillary room or small living room.
  4. THE BOARS
    THE BOARS
    Nov 25, 2004
    4,190
    68
    +98
    im using a monitor short setup 906,905,903 will these be able to drive the type of speakers i have at the moment
    I was positive you had up the yamaha s600d
