Yamada DVD-5520 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,601
    7
    167
    Birmingham, UK
    +10,461
    This machine should be multiregion out of the box, but if not, try updating the firmware from the Yamada site.
    # Extract the file to your hard drive and burn the 11121213.BIN to the root directory of a CD. Use Standard ISO9660 Format and finalize the CD. Don't use Joliet, multi-session or XA Format!
    # The CD title must be P80J0001. Don't copy both firmware versions on one CD. You have to use separate CDs.
    # Insert the ready CD into the DVD-Player and press Play when prompted.
    # When the CD drive opens take out the CD and wait about 1-2 minutes.
    # The DVD player will be reset automatically and should be multiregion.
