Yamada DVD-2500 multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 21, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,558
    7
    167
    Birmingham, UK
    +10,391
    * Press Eject button on the remote control to open/eject the disc tray
    * Press numbers 2, 8, 1 and 2 on the remote control, the factory default region code will be displayed on the TV screen.
    * Press Play button to select the region (please note that we defined digit 9 instead 0 for region free) code
    * Press Setup button to exit settings
  2. Kefre
    Kefre
    Hi there,
    Is there hack for Yamaha DVXS200 home cinema system?
    many thanks :)
    :lease:
  3. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Try
    1/ Power ON
    2/ Press PLAY
    3/ 2 7 4
    4/ 222222005255
    5/ Play
    If not, you need a firmware mod disc for it from a yamaha dealer (will cost)
  4. Kefre
    Kefre
    many thanks :)
