Yamada 8400X DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by SuperBob, Apr 30, 2005.
  1. SuperBob
    SuperBob
    Can anyone confirm RGB in on this model?
  2. 8472
    8472
    Sep 2, 2005
    90
    11
    It has an RGB Scart and component, i think. :smashin:
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    ... and, usefully, the RGB loops through in standby.
  4. richwill
    richwill
    Aug 30, 2005
    190
    Banbury
    +3
    Yes you can set the RGB manually from within the menus.
    Spec's as follows:
    • Massively compatible, Multi-region DVD recorder and DivX Player
    • Recordable disk formats - DVD+RW, DVD+R
    • Format compatibility: MPEG1, MPEG-2, MPEG4, DivX 3.11, DivX 4.x, DivX 5.x, Xvid, MP3, WMA, PCM, JPEG & AVI
    • DVD Recorder time capacity - 4.7 GB (12 cm single-sided) Up to 360 minutes (6 Hours)
    • Front mounted DV link digital input, for recording directly from camcorders
    • Front mounted USB port for direct file transfer from PC mobile storage device
    • Selectable NTSC or PAL video system output
    • Connections: SCART, Video CVBS, S-Video, audio L/R output, 5.1 coaxial audio output, Digital audio output (optical & coaxial), USB & DV link digital input
  5. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Is this just for JPEG display, or can you play an MPEG4-based video file back from this port (eg from a ~1GB USB pen drive)?
  6. richwill
    richwill
    Aug 30, 2005
    190
    Banbury
    +3
    It's quoted as being used for JPEG. I'm not sure if it's possible to run MPEG4 from this port. Might be worth a play around with. I'll also be testing Nero's MP4 compatability too. I'll let you know how it goes, though this may take a few days as i've other things on the go.
    rich
  7. 8472
    8472
    Sep 2, 2005
    90
    11
    I wouldn't bother, tbh - i've tried and it doesn't play it :(
  8. richwill
    richwill
    Aug 30, 2005
    190
    Banbury
    +3
    Cheers mate, saved me a job :D
  9. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    OK thanks.
  10. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I have one of these and the remote only works up to about 4 feet. Is that normal?
  11. richwill
    richwill
    Aug 30, 2005
    190
    Banbury
    +3
    Nope. Phone the store you bought it from
    Rich
  12. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I've emailed them twice....no answer. They were quite efficient before I paid them!
  13. richwill
    richwill
    Aug 30, 2005
    190
    Banbury
    +3
    I'm not sure if it's allowed but perhaps you should name and shame them? or phone UMAX in Milton Keynes
    http://www.umax.co.uk/WebNew_UK/
    funnily enough the 8400X doesn't appear on their website.
    contact number
    Umax UK Ltd.
    Unit 53, Potters Lane
    Kiln Farm
    Milton keynes MK11 3HQ
    Phone: 0870 906 3300
    Fax: 0870 906 3310
  14. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I only emailed last a couple of days ago. I'll give them a bit longer. I bought a PWD7 with it as a package.
  15. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Batteries in the remote dodgy?
  16. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Not unless the new ones I replaced them with were dodgy too!!;-)
