Yamada 5520 Multi-region 5520
Discussion in 'Blu-ray & DVD Players & Recorders' started by VinneMac, Sep 17, 2003.
  1. VinneMac
    VinneMac
    Ordered this player off amazon and I received the player but they have not enabled the Multi-region playback on the player.
    Does anybody know what the code is to enable Multi-region playback ?
  2. Garrett
    Garrett
    Apr 21, 2001
    33,077
    2
    167
    The best thief you’ll never see.
    +4,355
    If you have no luck getting hack ring Amazon, and ask them if they can help if not tell them you want a replacement and they should pick yours up free or reimburse your credit card with the postage back incurred.
  3. Jonathan West
    Jonathan West
    I received my 5520 today from Amazon, plugged it in etc. - no multiregion either!!! I'll repeat the plea - anyone know how to hack this one if it can be done?
    And I have contacted Amazon to ask them about replacing it ...
  4. Badger
    Badger
    Jan 21, 2002
    257
    [edit] Ignore me, it's Yamada not Yamaha
  5. Jonathan West
    Jonathan West
    I contacted amazon, and they said they can send a CDROM with simple instructions to multiregion enable the unit ... although I returned it anyway as it had another fault - awaiting a replacement now. Suggest you contact amazon and no doubt they will send you the CDROM to enable your player.
  6. hermit
    hermit
    Contact support@umax.co.uk.Give them model no and explain it should have been multi-region,but isn't.They will send you a file,burn this to disc put it in player,it then ask's you to push play.Two minutes later it's multi-region.This is what i did after waiting three day's for Amazon,asking me to return it.:clap:
  7. hermit
    hermit
