Yam750SE reassign component in
Discussion in 'AV Receivers & Amplifiers' started by deman77, Jun 29, 2005.
  1. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    I have only have two component ins on 750: one named A (DVD) and one B (DTV/CBL).
    I need to reassign component in B to a different device as I want to connect my XBOX video to it but audio to VAUX.
    My SKY video goes direct to the screen and only audio gets connected to the amp to DTV/CBL. I know I could just configure XBOX as DTV/CBL and send it fully through it, and connect SKY sound as smth else but I already tought my YAM remote all SKY codes on DTV/CBL so if possible I would prefer to reassign the component. Anyone knows how to do it :confused:
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    I believe you do not need to do anything just plug into where you want. I have my PS2 plugged into the B component in and the sound into the MD input. I turn on the amp, select MD and all is fine.
    I still have sky sound going into the DTV/CBL input.
    Give it a go!
