yam sub
Discussion in 'Subwoofers' started by bobby100, Nov 12, 2004.
  1. bobby100
    bobby100
    Anyone out their got a yst-sw315 ? are they any good or do you recommend
    a different one.
    Kef Q5S FRONTS
    Kef Q95.2 CENTER
    Kef Q15.2 REARS
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The Yamaha range of budget subs have never been market leaders. To find out the subs that are recommended in the same price bracket have a read of the budget sub test sticky at the top of the forum listing.
  3. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    What is your budget Bobby100?? I have seen the 315 for £199 + postage.
  4. bobby100
    bobby100
    Thanks for the replys,My budget is about £300.00, do you think I should go
    for the kef 2500
  5. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    For that sort of budget you should go for the BK xls200 from www.bkelec.com or the vita 100 as its on special offer. They also do another version of the xls200 that is downward firing.
  6. Apothis
    Apothis
    Would just like to add a recommendation for the Vita 100 that Dfour just mentioned. Although I havent heard the BKXLS to compare it, the Vita is a cracking sub, very pleased with mine. And cant recommend BK themselves as a vendor highly enough either. Very very pleased with the service from them.
    Apothis
