Yam RX-V650 vs. DSP-AX750SE - is £110 extra worth it?!
Discussion in 'AV Receivers & Amplifiers' started by Jonmurgie, Jan 13, 2005.
  1. Jonmurgie
    Jonmurgie
    Jun 6, 2004
    806
    Cheltenham, Glos
    +44
    Having popped into Richer Sounds today they had the 650 on the shelf running through the new Mordaunt Short Genie's (which sounded STUNNING!) and their current price on the Yam is just £270!!
    I mentioned to them I was looking for the 750 and the chap said 4 of the staff have them at home, so it seems to be a very popular choice! As they will price match UK websites they can do the 750 for £380 :)
    On paper there doesn't seem that much difference between the 2 units, and as a relative newbie to the field of decent home cinema would I really notice a difference?!
    So basically, do you think I should save the money and go for the 650 or is the 750 worth the extra £110?
    Cheers.... know you guys hate all these newbie questions!!
    Jon
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    I would get the 750 as it upconverts to component. Take a look on www.technikdirekt.de where you can get it for about £300, all you need to do is change the plug. Cracking value.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,825
    London
    +1,092
    Quoting Reservoir 51:
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    What hi-fi seems to think its worth the difference, but then again they probably would be getting some nice advertising money from yamaha.
  5. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    As I was told when I asked the same question - 'spend the extra now, as you'll only upgrade in 6 months time anyhow'. I've got the 750 - Genie combo and it is superb.
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    After the 750 there is a bit of a step to the 1500 (in cost at least) and as such it might be worth going for the best in the range and you could possible reasonably afford, especaly if its gonna get used every/most days.
  7. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,460
    71
    Southsea
    +69
    Sorry to hijack the thread but does anyone know what the J.M. Labs Sib & Cub Mk2 speakers are like when paired with the yahama 750SE amplifier?
    Thanks.
  8. Jonmurgie
    Jonmurgie
    Jun 6, 2004
    806
    Cheltenham, Glos
    +44
    Thanks for the responce guys... interesting as well as it's clear the 750 is the one to go for!
    So be it..... :)
  9. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Jon, you may wish to check out the German sites for the 750 too, not only for price, but they do the RX750 which is a receiver, only the AX750 (Amp only) in the UK.
  10. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    You can also find them on ebay.de
