Yam RX-V650 config
Discussion in 'AV Receivers & Amplifiers' started by jaymz, Nov 8, 2005.
  1. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    Before i started watching Return of the Sith i went through the THX audio setup. This ran through no problems and all speakers responded correctly, including my rears (MA BFXs) for surround and back speakers (e.g. 7.1).
    However when i go to play the movie the amp selects Dolby EX for a split second and all icons on the front panel light up for EX (L,R,C,LFE,SL,SB,SR) but it then goes to Dolby Std and the SB icon turns off.
    I am confused why the amp plays the THX test ok and selects EX but not when playing the movie?
    During my random button pressing to try and get this to work I turned on Speaker A (this is normally unselected) i got a distinct boast in sound quality and presence. Should this be normally selected (the speakers work with it selected but not when Speaker B is selected as there are no speakers connected)
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    My understanding is the Sith DVD does not have EX flagged? It needs to be switched on manually...
  3. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    I assume this means there is no header in the bit stream to automatically tell the amp to change to this mode, interestingly when i cycled through the amp surround modes EX was not available (i think it is normally though)?
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Just turn on pl2x and that will do it.
  5. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    ok will try tonight but isnt pl2x different to DD EX?
  6. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    Sorry was not able to try, my nephew had been round and "borrowed" the disks!
    Now that i have it back.......
    When i cycle through the input options i do not get pl, pl2x but i do when i put in a movie recorded in stereo?
    I have also tried Attack of the clones and the amp does not give me the DD EX option or pl or pl2x but i am not sure when the audio is on this disk.
    Any other ideas?
