yam dsp ax620 and Mordaunt Short speakers
Discussion in 'Home Cinema Speakers' started by iwilliams, Jun 3, 2004.
  1. iwilliams
    iwilliams
    I have just brought some Mordaunt Short speakers for my setup
    to replace my old speakers. When I looked at the sub its got L and R phono
    connecters for the input, but my yam amp 620 only has one sub phono output.
    The speakers are the Mordaunt Short and the sub is the 308
    Whats the best way forward here.
    Would it be ok to buy some sort of doubler to make the phono doubled output??
  2. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    No need the consensus of opinion is to connect to the left input. I believe it says so in the manual.
