yam 630 impedence setting
Discussion in 'AV Receivers & Amplifiers' started by rdt123, Jan 19, 2003.
  1. rdt123
    rdt123
    Dec 14, 2002
    1,516
    Busting out a restaraunt in Queens, NY
    +33
    just wondering which setting on the rear of the amp to use. My speakers are all from the wharfedale diamond 8 series and i believe they have an impedence of 6 ohms.
    cheers
    rob
  2. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    Hi mate, I also have a full set of diamond 8's and a Yamaha 620.
    Don't worry about the settings on the back, just leave it on the default setting and you will be fine.
