Yam 620, how much will it support
Discussion in 'AV Receivers & Amplifiers' started by dnrc, Nov 8, 2004.
  1. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    I've got a yamaha 620rds receiver and would like to know if anyone know anything about what it will take in terms of weight on top of it.
    I want to reshuffle and sit a 17" CRT on top of it, anyone tried this, would it take it. I'm sure it would take the weight but maybe not on the area it will be covering. And you wouldn't be able to support it with a shelf or whatever sitting on there because of the need for ventilation.
    Anyone tried / have any ideas?
  2. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Umm, have you thought about the build-up of heat if you put a tv on top of it? Forget the weight issue - the receiver should be able to take 15-20kg no problem.
    Even though the air vents are at the side, I'd be worried about ventilation, given that the tv (crt?) can get pretty warm itself. Also, think about the effect of EMI/RFI interference from both units affecting each other. I doubt the tv is very well shielded from either of these things.
    DT
