Y connector needed
Discussion in 'Cables & Switches' started by Akcron, Sep 9, 2005.
  1. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    Hi folks, After reading through the forums i see i will need to put the signal into the VGA socket of the lcd to get both the best picture from the PC and also progressive scan fdrom my DVD. ( oh its a tosh 27wl56 ) i have got 2 good quality cables to use but i dont want to ruin the signal by using a cheap either y connector or switch box . The question is does anyone know what would be best to use, the y cable or switch box? and where can i get one? tHX FOR YOUR HELP Akky :thumbsup:
