Y/C Delay on 40" RPTV
Discussion in 'General TV Discussions Forum' started by slay, Oct 21, 2001.
  1. slay
    slay
    Sep 14, 2001
    62
    11
    Cumbria
    +3
    Does anyone know if the y/c delay is adjustable on a 40WH08B.
  2. damjanb
    damjanb
    Hi again, Steve;
    I thought some more about this, and
    would like to emphasize some basics
    that you need to be sure of before
    looking for exotic options such as
    Y/C delay adjustment.
    Your problem was green haloes, as in
    the first image on http://nl.ijs.si/~damjan/calibrate.html
    What you need to make sure first is
    that the set is converged as nearly
    as possible, in service convergence.
    On my set, a different one, I noticed
    haloes only after I made the convergence
    as tight as possible - only then did
    they become apparent, and only later
    did I find out that Y/C delay could
    fix them.
    And, of course, leave the set on for
    about an hour before doing any sort
    of convergence.
    If I remember correctly, Delta was
    knowledgable about convergence on
    Toshibas, and Gordon from http://www.convergent-av.co.uk/
    should also be able to help.
  3. slay
    slay
    Sep 14, 2001
    62
    11
    Cumbria
    +3
    HI
    Definately converged ok in service mode on all screen sizes for pal and ntsc.
    Have orderd a DVD with component outputs to see if that helps.
    Steve
  4. damjanb
    damjanb
    yup, sounds reasonable to me: if the
    problem is not spatial (convergence),
    it might be temporal - timing of the
    (component) signals, which connects
    with the solution that worked for me
    (adjusting Y/C delay).
    Component output from a DVD should
    also have more precise timing, and
    suffer less processing inside the TV.
    Let me know how it works!
    I should have asked you before: how
    does the problem depend on the form
    of the signal? (composite, Y/C, RGB
    - which one is worst?)
    On my set, I noticed that RGB was
    actually worse than S-video (more
    color ringing around edges), so i
    looked at the schematics, and saw
    that RGB is immediately turned to
    YUV and is then further processed
    (for 100 Hz, zooms, etc.)
  5. slay
    slay
    Sep 14, 2001
    62
    11
    Cumbria
    +3
    all sorted, new dvd with component outputs.
    Picture is superb !!!!!!!!!!!!! :))))))))))))
  6. damjanb
    damjanb
    Greeeat - enjoy!!
