Y-adaptor
Discussion in 'Home Cinema Speakers' started by pizzacheaze, Dec 3, 2003.
  1. pizzacheaze
    pizzacheaze
    just entrered the world of sat/subs
    my sub has 2 inputs and my amp has one sub output, guess i will be needing an adaptor?
    where do i get one and do i need one
  2. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,505
    Newbury
    +175
    depending on what your amp is, you normally only need one sub output. AV amps usually output mono information for the sub, thus one cable will suffice.
    a lot of subs have two inputs, some have stereo inputs (usually for routing on to other systems), some have one input that is more sensitive than the other. i would use the normal input if you have that choice.
    Chris
  3. pizzacheaze
    pizzacheaze
    the sub has 2 inputs, so do i just use any?
    sub is a velodyne spl800
  4. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,505
    Newbury
    +175
    just had a look at the specs for your sub.
    it says, 'outputs - Line-level 80Hz up' which says to me that your inputs are stereo and it will actively filter audio to go onto a satelite system via another amp. however, if you have an amp with one sub output and you are not using your sub to route audio on to satelites, then you can use either input.
  5. pizzacheaze
    pizzacheaze
    yes thanks for that chris, i was wondering i i was 'missing out' if i just used one
  6. mudan
    mudan
    Nov 26, 2001
    172
    Solihull
    How about the idea that the sub may sound better if both line inputs on the sub are used ?
  7. pizzacheaze
    pizzacheaze
    sourced a y-adaptor now, so everything will be hunky-booming
  8. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    How? Or why? Anything to back-up that 'idea'?
  9. Supra
    Supra
    Dec 12, 2002
    430
    Kent
    +14
    where did you get a Y adapter from, im after one to bi-wire my speakers.
  10. wookie
    wookie
    Using a Y lead on the subwoofers low level stereo inputs halves the subwoofers input impedance and gives a 3db gain.
    If each input presents a 22kohm impedance, using a Y lead will give an 11kohm input impedance.
    IHMO, Y leads are Only of use if you use Auto mode on the sub and listen at low volumes.
  11. pizzacheaze
    pizzacheaze
    i'll try it with, and without, to see what sounds the best
  12. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    Aldershot, Hampshire
    +267
    It helps with regard to the subs auto off function in my case. The signal is a bit stronger with two connections so the lagg involved when an lfe channel springs into life is less. It doesn't appear to improve sq in anyway with one or two connections just stops the frustration of having to keep my sub on the on position all the time.
  13. puddleduck
    puddleduck
    Jan 24, 2003
    1,816
    48
    Lake District, near as dammit
    +50
    I use a Y-spliiter with my Velodyne CHT-15 - it seems to have made the bass much deeper (so much so I had to ramp it down a bit with the knob on the back), and it "wakes up" much quicker at low volumes.
    Worth giving it a shot, as splitters are only a couple of quid.
  14. mudan
    mudan
    Nov 26, 2001
    172
    Solihull
    Apart from the expensive Y - adaptor from QED anyone know where to source one from?
    Supra, these Y-adaptors are for subwoofers or phono connectors and not banana plugs.
    Thanks,
    Dav
  15. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    +267
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,495
    71
    Newcastle
    +83
    Same here with my CHT15, about a 5-10db increase!!
