xvid?
Discussion in 'Microsoft Windows' started by spikerules, Aug 26, 2005.
  1. spikerules
    spikerules
    Hi guy's,
    I just installed media center 2005 today and was a bit upset to see that Microsoft hasn't given up the fight and opted to support xvid files! Is there any way to MAKE it support them?
  2. lisag
    lisag
    Jul 14, 2004
    5,676
    Essex
    +333
    Just install the xvid codec to your MCE machine.
  3. spikerules
    spikerules
    I've done what you have suggested and Windows Media Center just crashes out to desktop everytime I install the codec! When the codec is not on my HD the media center works fine!
    Any other suggestions?
  4. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    Try the Divx codec from www.divx.com...
  5. spikerules
    spikerules
    That worked wonders... thanks!
    May I ask what the difference is to using either xvid or divx?
    Spike
  6. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    There both different codecs/compression formats, though similar in nature, Not sure but last time I when I had xvid videos I just installed the divx codec and it acts as a decoder for xvid files as well as divx....
  7. lisag
    lisag
    Jul 14, 2004
    5,676
    Essex
    +333
    Weird - I have the latest xvid codec to decode divx and xvid!! Anyway, glad it worked eventually. :)
  8. spikerules
    spikerules
    The same thing has happened again with the divx codec! Maybe its ffdshow screwing it up? I tried uninstalling ffdshow, but media center still crashes. I need to uninstall the codec for it to work. What is going on!?
    Spike
  9. lisag
    lisag
    Jul 14, 2004
    5,676
    Essex
    +333
    Eek :eek:
    This was the most difficult thing to get over for me when I set up MCE, I found that installing the minimum amount of codecs as possible was the key. Also make sure you have the latest official MCE supported drivers for your graphics card.
    I just have the nvidia dvd codec, the latest xvid codec to decode divx/xvid files, and divx3.11 for older divx files, and ac3 filter.
    That seems to play back everything and has been stable for a while.
    lisa
  10. spikerules
    spikerules
    I know its a real shambles:) Oh well back to the drawing board! hehe
