Question XTZ 12.17 vs XTZ 1x12 Cinema vs PB 2000
Discussion in 'Subwoofers' started by Crabbie, Jan 8, 2017.
Tags:
    1. XTZ 12.17
    2. XTZ 1x12
    3. SVS PB2000
    Results are only viewable after voting.
    1. Crabbie
      Crabbie
      Jan 31, 2012
      531
      46
      Manchester
      +131
      Hi All
      Does anybody have any experience with these Sub's if so what are peoples opinions regarding them is the 1x12 better than the 12.17 or just a different design and then is the SVS better or Worse. All opinions Welcome
    2. HamidS92
      HamidS92
      Sep 23, 2016
      75
      Gateshead
      +14
      I have the XTZ 1x12 and a family friend has the 12x17 and on paper they appear to be similar spec wise.
      However after listening to both extensively if you can afford the 1x12 they go for that one. I think the design of the two boxes are ultimately what makes the 1x12 better. Don't get me wrong the 12x17 is a fantastic subwoofer but personally I prefer my 1x12. To my ear it goes lower and louder. You can always go over to Jag and test them both if your local.
      I don't have any experience of the pb2000 but it was between that and the xtz and I chose the xtz, although I'm sure the pb2000 is also a beast!
      Either way I recommend you listen to as many as you can before purchasing.
    3. rgledhill
      rgledhill
      Nov 19, 2016
      76
      Stoneleigh, UK
      +33
      I'm having a similar discussion on another thread, talking also about the BK Monolith and Arendal 1723...
